radial pattern on a surface
I'm working with Inventor 2018. I want to put a pattern on a circular disk that is a radial sawtooth. Similar to the top of a checker piece except that each tooth tapers towards the center of the disk. When two of these disks are mated to each other they form an adjustable hinge that can be locked into place. It is similar to the picture, although this is not a sawtooth. I can create the disk but I have no idea how to approach the pattern.
johnsonshiue
Hi! Based on the sketch you provided, I think it is highly doable in Inventor using two triangular profiles in Loft. Please share your attempt here so forum expert can provide further guidance.
Many thanks!
Software Test Engineer
