"Select component" box when creating new drawing
bniMW775
bniMW775
hi,
just messing around with a new title block, but when creating a new drawing, i get this "select component box.
now what did i do wrong?
dont get this with the old ones...
Best regards
Brian Nielsen
Eldan recycling A/S
admaiora
 you attach the file?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
bniMW775
sure, here it is.
Best regards
Brian Nielsen
Eldan recycling A/S
admaiora
Hi Brian,
I can't reproduce your issue.
Admaiora
bniMW775
did it once again.
copied from old one, but this time with no "errors".
do know what I did wrong first time, but now it's working.
But thanks anyway 🙂
Best regards
Brian Nielsen
Eldan recycling A/S
blandb
This usually happens when the template has a view saved in it. Similar to the default sheet formats with a certain size sheet and "X" amount of views.
If you open the template and delete the view, the error should go away.
I opened your supplied drawing and on sheet 1 there is view9...Delete it in the template.
Autodesk Certified Professional
bniMW775
thanks. now i know - if I can remember it...
just created a new one - copy from old one, and did the changes needed.
no errors.
Best regards
Brian Nielsen
Eldan recycling A/S
