"MASS" iProperty Precision
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Thanks in advance for any help with this problem. It has to be the most frustrating thing.
Using Inventor 2016 and we are using "MASS" in our BOMs in a formula so we group like parts created in "Frame Generator" together. We have an equation using iProperties that create a "Part Number" to do this grouping, it is (=Material Size x <G_L> x <MASS>. The "G_L" and "MASS" are Inventor iProperties, I find the "G_L" in my parameters but don't see the "MASS" anywhere (this MASS is different than the Mass under iProperties/Physical). On the attached screen shot the fifth line has (11) parts that are the same size and <MASS> so groups them together. The issue comes, when on this example, the first line the mass = "5571.219081" (don't have a clue what this MASS is, but don't care). When I created this frame generator part I had (6) with mass of 5571.219081 and (3) with mass of 5571.219082 so it did not match so did not group creating (2) lines on my BOM so I had to go into iProperties on each part and manually override "Part Number" to show same.
I have Googled this and come across some discussions and some say they are (4) places and some say they are (6) places like mine. Would like to make it zero places if possible because the "MASS" is precise enough as you can see the third and forth lines are the same material and length but the part in the third line has a miter thus creating a different "MASS".
Does anyone know where I can control the (6) place precision for the iProperty?
