"Errors detected in the profile for this Feature" despite Sketch Doctor saying otherwise?
drafting3QE6L
drafting3QE6L
Customer wants a profile of an M16 Rifle laser cut into his product and provides a .eps file. I have since exported the .eps to .dxf through Illustrator and despite my tinkering, Inventor refuses to acknowledge the closed loop as valid.
The specific error is "Errors detected in the profile for this Feature. Edit the Sketch to fix the errors."
Sketch Doctor claims no issues, and I am able to use AutoCAD to put a hatch inside the profile. I will also need to scale the profile non-uniformly and the only way I know of how to do that is through AutoCAD.
The profile comes from a stock image website and perhaps they export a different file extension that would work better than .eps.
What would be the best approach to this issue?
I have attached the .eps but for unknown reasons the Forums is not letting me upload the .dxf, so I am attaching the .dwg save of that same file.
johnsonshiue
Hi! This kind of shape is indeed difficult. Inventor is a precise modeler. Anything that cannot be properly dimensioned will have trouble modeling in Inventor.
Did you import the dwg/dxf to Inventor or you use DWG Underlay workflow? Please share the ipt file here. There might be alternative workflows to help make it work. It is also possible you may need AutoCAD to help edit the curves (SPLINEDIT or PDEDIT).
Many thanks!
Software Test Engineer
drafting3QE6L
I do not even know what DWG Underlay is, so I shall investigate that option. I have done a lot of noodling around with blocks in both AutoCAD and Inventor. There was another logo that was much more geometric and playing around with blocks was how I was able to get it to work.
I suppose if all else fails I could brute force it by tracing the profile with a sketch and imported image
drafting3QE6L
In the end, I inserted the profile as an image and traced around the edge with arcs and lines. It worked so well I wish I did that from the start.
