"Bolted Connection" Workflow alternative -- is it common/supported by Autodesk?
The other day in making a model I came across the functionality of inserted parts into a assembly in a positional rep; essentially allowing the ability for different configurations.
This leads me to wonder whether this would be a good workflow for bolted connections -- Every bolted connection that uses the same size and number of hardware components becomes it's own PHANTOM assembly, and every different usage of this set-up that has a different component spacing is used as a positional rep.
That way, when inserting the new BC's, you simply have to select what positional rep (spacing) you want to use for the BC, and can inserting using a single insert constraint. If there were a new spacing you wanted to use, you would just have to open the BC and add it as a new positional rep, then change it to that positional rep in the file. I would think you would also want to leave the master rep with the constraints suppressed/with free DOF's in case you ever wanted to turn it into a flexible assembly and drive it for that instance.
This leads me to wonder what things might bug up with it unexpectedly, or how it will affect the load time of the various files.
Can someone please share their insight/knowledge on the situation?
Sample assembly picture attached.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
