Hi all,
When I export a inventor drawing 2016 to autoCAD dwg, the autoCAD blocks not go to the autocad dwg drawing.
What I try to suceed? Is a problema with Inventor 2016?
In the image attached below, the block that have this issue is focused in red.
Thanks advanced!
I've seen some instances where hatching is not carried over but I don't think I've come across a block not showing up once the Inventor drawing is export to an AutoCAD drawing. Is it possible to share your original Autocad block that is in your Inventor drawing?
Mark Lancaster
& Autodesk Services MarketPlace Provider
