Anybody know, it possible using keyboard shortcut switch options in extrude feature (beetwen add material, delete material, common and new solid). It could save a lot of time for me, beacuse now i use mouse ๐ Please look at attached pdf and you udestand what i mean ๐
You can create short cut keys yourself. See below.
Now, with that being said, to toggle between solid and cut, that would require iLogic if it can be done at all.
Maybe a routine like this would help.
https://forums.autodesk.com/t5/inventor-forum/extrusion-using-ilogic/td-p/3573250
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Nope
