Inventor Forum
Quick One: Flat Pattern Actual Area iLogic Command
2 REPLIES 2
Vadim-the-Engineer
342 Views, 2 Replies
Looking for a command to get the actual area of the flat pattern similar to SheetMetal.FlatExtentsArea...
2 REPLIES 2
Hi @Vadim-the-Engineer,
I don't think there is anything built into iLogic for this, but you can use the API to do it. Here is a quick example.
I hope this helps.
Curtis
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
Try
	Dim oDef As SheetMetalComponentDefinition
	oDef = oDoc.ComponentDefinition
	Dim oFlatPattern As FlatPattern
	oFlatPattern = oDef.FlatPattern
	oArea = Round(oFlatPattern.TopFace.Evaluator.Area,3)
	MessageBox.Show("Flat pattern area: " & oArea & " cm^2", "iLogic")
Catch
	MessageBox.Show("Error: Verify that a flat pattern exists", "iLogic")
End Try
@Curtis_Waguespack,
Something kind of cool I stumbled across a while ago - if you add a line of code that references the flat pattern extents, such as shown below, then iLogic will just create the flat pattern for you instead of causing an error.  You don't actually have to use the extents for anything - simply referencing one of them is enough.
This would let you pull out the Try / Catch error handling, and instead makes Inventor just fix it for you if the flat pattern is missing.
X_Measure = SheetMetal.FlatExtentsLength
