Service is my middle name (actually it's Sean but they both start with an
"s")
Sean Dotson, PE
Autodesk Inventor Certified Expert
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kirk A." wrote in message
news:4022a46d$1_2@newsprd01...
> Now THAT is a Hotfix.
> Thanks,
> Kirk
> "Sean Dotson" wrote in message
> news:40229e7b$1_2@newsprd01...
> > It was a bit more complicated than that but I fixed it. I could never
get
> > it to reproduce. Thanks Kirk...
> > See the announcement (new post) for a new version to download...
> > Sean Dotson, PE
> > news:40229425$1_1@newsprd01...
> > > I think I know what is causing my problem now.
> > > If the"Create Custom Props if New" box is checked, iPropWizard is
> > expecting
> > > a value to be entered in any of the property fields that are shown in
> RED.
> > > If I don't enter something (it can be any text) then I will get this
> > error.
> > > Problem is, I don't always know what the correct value for the field
> when
> > I
> > > run iPropWizard. If that is the case I have to enter a bogus value
then
> > > enter the correct value later.
> > > I'm no programmer, but it seems that this could be fixed with some
error
> > > trapping code.
> > > Thanks,
> > > Kirk
> > > news:40228d20$1_3@newsprd01...
> > > > Not sure. This error is sporadic. I've never gotten it but some
> people
> > > > have. I've never been able to track it down.... :(
> > > > Sean Dotson, PE
> > > > news:402285a8_1@newsprd01...
> > > > > Thanks, I will work on this later. Right now I have another
> problem.
> > I
> > > > get
> > > > > a runtime error. After I get this error, I have to close Inventor
> and
> > > > > restart in order for iProp Wizard to start again.
> > > > > I noticed this problem after I changed the configuration to
"Create
> > > Custom
> > > > > Props if New". If I open a file that does not have any of the
> > > propertiese
> > > > > shown in RED, i.e., custom properties already exist, then I don't
> get
> > a
> > > > > error, but if I open a file that is missing one of the custom
> > > properties,
> > > > I
> > > > > get this error.
> > > > > Any ideas?
> > > > > Kirk
> message
> > > > > news:40227623_1@newsprd01...
> > > > > > The INI files do not store the property, alias or options
> settings.
> > > > These
> > > > > > are stored in the registry.
> > > > > > The INI files simply provide the list items for each alias name.
> > The
> > > > help
> > > > > > file explains how to add to them. Let me know if you need
further
> > > > > > assistance.
> > > > > > Sean Dotson, PE
> > > > > > news:40227257_3@newsprd01...
> > > > > > > I have set up the property list for all of the drawing types
> > > > > > > (iam,ipt,idw,ipn). It doesn't seem to me that these are being
> > saved
> > > > in
> > > > > > the
> > > > > > > .ini files. I say this because the date for all the ini files
is
> > > still
> > > > > > > 11/14/2003 and when I open any of them, I don't see anything
> that
> > > > looks
> > > > > > > fimiliar.
> > > > > > > I searched my HD and there was only one occurance of each of
> these
> > > > > files.
> > > > > > > How do I save my settings in the ini files?
> > > > > > > Thanks,
> > > > > > > Kirk
> > > > > > > Inventor R8, sp1
> > > > > > > Dell 4550
> > > > > > > WinXP Pro
> > > > > > > P4, 2.8 Ghz, 1G
> > > > > > > Quadro 900 XGL
> > > > > > > nVidia v6.14.10.4403
> > > > > > > 1280x1024, 32 bit
