Question about fillet and extrude increments
RGHaythorn
RGHaythorn
I'm using Inventor 2025 and when I fillet an edge, or try to extrude something, when I make adjustments by clicking the arrow and pulling it, it always seems to adjust in increments and I can't figure out a way to turn it off. Is there a way to disable this incremental snapping? Thank you for your time!
CCarreiras
Hi!
I believe is not possible.
Tip: you can zoom to control better the increments behaviour, but you can not set other values of increments.
CCarreiras
johnsonshiue
Hi! The increment value is controlled by a document setting. Go to Tools -> Doc Settings -> Model -> 3D Snap Spacing and enter the desirable increments. It will apply to all 3D commands. You may also change it in the template files so that the newly created files will have the desirable snap spacing.
Many thanks!
Software Test Engineer
