Put dimsension in for circle pattern
I have atttached a file. I want to know how to dimension the circle pattern i have marked with a dimension for the diameter for all the circles
JDMather
Delete that centermark you already have.
Start the Centered Pattern centermark tool.
Click the central hole and then each one of the holes in a pattern (pick the first hole in the pattern a second time as you close the circle.  Right mouse button create.
You now have a "bolt circle" centerline to dimension to.
As I recall some way or another there is also a method of doing the bolt circle without a central hole (or cylindrical feature), but you have one - so not a problem.
Post back if you can't figure it out.
