Hello gurus,
Over the past year I have been working on simplifying my job here at dci. There is a lot of repetitive information that has to be entered for every part its time consuming and generally results in a lot of user error. I have created a plethora content center parts that can be reused just by filling in custom fields for ID, knuckle radius, material thickness, etc. which all populates to its iProperties.
Now the question I have is: is there a way that I can pull information from a part that is already in the assembly. IE When I insert the leg for this tank into the model, is it possible for me to somehow select the head that it attaches to and have it draw the pertinent information from the model? This will reduce repetitive data entry.
Thank you for any/all help
Kevin
Kevin Grose
