Hi! I’m a beginner publishing parts in the content center library, but if I publish an ipart, I guess that the folder with ipart members will be saved in the content center folder, but what will happen with the ipart parent? Will it be saved as well in the same path?
Solved by CGBenner. Go to Solution.
When you publish an ipart as a Content Center family, the CC files that are eventually generated from that will go into your default Content Center file location as set up in your Application Options. The original part itself will stay in whatever location you have it saved. I usually held onto those or checked them into Vault for any future needs. Once published though, most changes you may need can be done in the Family Table editor in Content Center.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
