Project with Sub-Projects?
nucleusgmbh
nucleusgmbh
Hi guys,
first of all: we are using IV 2016 with vault.
Our company is constructing special-machines. Every machine is different but uses same components.
Some example:
Project a)
Cutter-Unit with several sub-folder, assemblies and part
Project b)
Complete machine where one part of it is the cutter-unit
Project c)
Complete different machine which also includes the cutter-unit
Earlyer we used only one Project with several sub-folders. This had a massive problem:
We couldn't prevent that someone, somewhere referenced a part from a different project. If someone modifies this part now because he doesn't know it is referenced from a different machine, he "destroys" the other project as it does not represent the real status again.
Thats why we changed our structure and use one project (ipj) for each machine now.
But what is the best way to use sub-assemblys now? Is there a function I don't know to use sub-projects?
From software-development I know something called sub-modules (git).
CU
mts
mcgyvr
The key for your company problem is that each project files are totally independant of other projects files.. single projects as you have switched to now solves your problem.. assuming each project points to a new folder and ALL files including subassemblies are stored inside that folder.
Subassemblies are no different than any other assembly or any other part files..
Of course you also said.. "each machine is different but uses the same components"... well now it really doesn't use the same components
You might still call it "bracket1" but bracket1 could be modified for each project and is no longer the same.. so its not the same component (by my definition anyways)
Sounds like what you may have done instead of indivudual projects is use library locations to essentially "read only" on your common parts that will never change..
PaulMunford
I think that projects are a red herring here. It sounds like you need to sort out revision/version control. Libraries would be a good place to start. Do you use Vault?
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
nucleusgmbh
Yes, we use vault.
The problem I have with libraries is that I don't know how to parts in it.
mcgyvr
@nucleusgmbh wrote:
Yes, we use vault.
You simply include the location of the "read only" parts under the libraries folder of your project.
Then you can create another project that allows you to modify those files if needed...
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-3C72B1C2-72BC-4CD4-A2F4-66228DC2DB73
