Hide dimensions in sketch
Message 1 of 14
Hello, inventor in 2015, there is not a way to hide the dimensions in sketches. This will allow to see more clearly the sketch.
Thank you.
Replies (13)
Message 2 of 14
JDMather
Right click on the sketch in the browser and select Hide Dimensions.
If you need to hide dimensions while editing a sketch - there is a trick to do that too, but first I would want to see an example file before revealing the trick.
Message 3 of 14
PaulMunford
Oo oo - I want to know that trick:)
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
Message 4 of 14
mcgyvr
I'm gonna guess he does that using sketch blocks...
Another way..
Here is a simple ilogic routine to hide dimensions.. This can be run from an active sketch.
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
oDoc.ComponentDefinition.Sketches(1).DimensionsVisible = Not oDoc.ComponentDefinition.Sketches(1).DimensionsVisible
Message 5 of 14
JDMather
Yep.  The sketch block can be fully constrained within the block and then the block can be fully constrained in the sketch.
When not editing the block - the dimensions are not visible.
But I am expecting the OP to post some auto-dimensioned "rats-nest" sketch.  We'll see!
Message 6 of 14
mcgyvr
woot-woot.. I win the Bozo button.. Smiley Very Happy
Message 7 of 14
Hello, thank you, I succeeded thanks to the rule.
To the right click this only works when I get out of the sketch.
Is there a rule to hide the points of curves if possible? (This allows me to better see the sketch).
I want to put an A4 default drawing file and portrait instead of landscape and A3. Do you know how I should do I do not find, thank you in advance.
Message 8 of 14
I can not definitely keep hidden dimensions? because when I draw a line for example and I click ok. the odds reappear.
Thank you.
Message 9 of 14
JDMather
Go into the Drawing Resources and create a new Sheet Format (and Border and Titleblock).
You should create custom templates for your company.
How are you learing Inventor?
Message 10 of 14
JDMather
Thank you.
I don't know what this means.
Attach your *.ipt file here and end all doubt.
How are you learning Inventor? Taking a class?
Message 11 of 14
baliasM74U3
Hi
I just want to make the dimensions in sketch 1 invisible/hidden. How to do that ?
Basil
Message 12 of 14
JDMather
Sketch Blocks - See Attached.
Message 13 of 14
baliasM74U3
Did you use ilogic in the sketch as mentioned above by PaulMunford ?
Message 14 of 14
JDMather
No.
