Project geometry symbol is red in Inventor.
Message 1 of 22
I drew a circle, extruded it, added a chamfer to one edge, then created a shell. Now I'm trying to create a sketch on one end, it won't let me project geometry.. It's allowing me to project cut edges and 3D sketch. In my tutorial project geometry is on. How can I fix this?
Replies (21)
Message 2 of 22
If you can post the file, it will be easier to see the problem.
Message 3 of 22
Message 4 of 22
mdavis22569
Can you post the actual file ...
Mike Davis
Message 5 of 22
johnsonshiue
Hi! I am not able to reproduce the problem. Could you attach the file here or send it to me directly (johnson.shiue@autodesk.com)?
Thanks!
Software Test Engineer
Message 6 of 22
Message 7 of 22
SBix26
Works normally for me on your file, I'm able to project any of the edges from the opposite end.  Have you closed and re-launched Inventor?  What are your machine specs, particularly the graphics system?
Sam B
Inventor Professional 2015 SP1 Update 3
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Message 8 of 22
File works normally here.
Message 9 of 22
LT.Rusty
I think you might be having a difficulty in terminology.
You notice that "project geometry" and "project cut edges" are different buttons, and one of them has red on it where the other doesn't.
PROJECT CUT EDGES will project any geometry that is cut by the plane on which your sketch lies.  PROJECT GEOMETRY will only project items that you select, and is not limited to only geometry on your sketch plane.
Rusty
Message 10 of 22
I have an i5 processor. I was told that was above minimum spec.
Message 11 of 22
mdavis22569
the I5 is fine ...what do you have for a video card?
Mike Davis
Message 12 of 22
Video Card: AMD Radeon R7 200
Message 13 of 22
mdavis22569
Card isn't an issue ...
? is this  the red you're talking about
If so you're fine ...
Mike Davis
Message 14 of 22
I am trying only to project geometry on the bottom surface. Cut edges, is projecting features from the the other end of the part that I do not want projected.
Message 15 of 22
Yes.
Message 16 of 22
I'm actually speaking about th Project Geometry symbol. It's red and unavailable.
Message 17 of 22
LT.Rusty
Does it look like the screenshot that I posted above?
Actually, no, never mind.  Take a screenshot of it and post that.  I want to see what this looks like.
Rusty
Message 18 of 22
LT.Rusty
PROJECT CUT EDGES takes the geometry that is sliced by the plane on which you're sketching.
PROJECT GEOMETRY takes existing lines, edges, curves, points, etc., that you choose.
Rusty
Message 19 of 22
It does look like the symbol in the video.
Message 20 of 22
LT.Rusty
That's what the button is supposed to look like.
I need to see if I can fire up my workstation and get a screencast recorded to demonstrate.
Rusty
