project geometry error:
102169026
Message 1 of 12
102169026
hello,
having the following issue when trying to select the edge highlighted in the below ss. won't allow me to project the geometry preventing a revolve function. cant see any errors in the sketch. any help appreciated.
thanks.
drwg updated
Replies (11)
Message 2 of 12
Alexander_Chernikov
Is this what you wanted?
Perhaps the problem is that you do not have any updates installed for Inventor 2023 (judging by the label in the file - build 153).
The current update for this version should be - 2023.5.3
(see at https://manage.autodesk.com/products/updates)
The updated file attached
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 3 of 12
steveh5
I think this is a good idea...but, there might be a better way to manage these favorites? You can use shortcuts in Vault Thick Client. Under your "Saved Shortcuts", you can create folders and then folders within folders and then create file/item shortcuts within. This allows you to easily have a bunch of favorites and organize them. You can do this with files as well as items if you use those.
Best,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
Message 4 of 12
102169026
hello Alexander,
ive updated and even installed the latest version 2026 and still the error remands. it must be an error in the original sketch/revolve. im try to revolve 360deg the highlighted region in your reply.
thanks for the help.
Message 5 of 12
89198826955
(view in My Videos)
that's right
Message 6 of 12
Alexander_Chernikov
Everything works for me with wheel yt+:
(view in My Videos)
Facebook | LinkedIn
Message 7 of 12
johnsonshiue
Hi! It seems that there is already a projected loop of the same face loop in the sketch. You are trying to create another projected loop, which is not allowed.
Many thanks!
Software Test Engineer
Message 8 of 12
102169026
Thanks for the reply,
i still cannot get the region to close and dont understand why. here is the new drawing. below imagine is line added 25.png
Message 9 of 12
89198826955
(view in My Videos)
Message 10 of 12
102169026
thank you kindly, this solved my issue.
i still have one question. why when i projected the geometry did this create a construction line rather then a solid line? is this normal??
thanks everyone who replied in the thread 🙂
Message 11 of 12
andrewiv
There is a  setting in the application options that makes projected geometry construction geometry.  Uncheck the box under the sketch tab and the projected geometry will come across as normal geometry.
Andrew In’t Veld
Designer / CAD Administrator
Message 12 of 12
102169026
thank you very much Andrewiv 🙂
