Inventor Forum
Project file - with same libraries - copy & rename - what is contentcenterguid
1 REPLY 1
coderuna
302 Views, 1 Reply
I have project files all with the same libraries.
Only thing is different in all .ipj is XML header
<?xml version="1.0" encoding="utf-16" standalone="no" ?>
<InventorProject contentcenterguid="pieugdapbbyh6y3kngvb15enbk" schemarevid="14">
I now just copy project file and rename it, contentcenterguid="pieugdapbbyh6y3kngvb15enbk" stays the same and works fine.
But if you make new project via inventor this contentcenterguid= is different everytime.
Is this contentcenterguid important or I can ignore this and leave duplicated...?
Labels (2)
1 REPLY 1
johnsonshiue
in reply to: coderuna
Hi! I think it is the Content Center library database ID. If you are using the exact same CC library, that ID should be the same. But, it is subject to change, if a new library is detected.
Many thanks!
Software Test Engineer
Technology Administrators
