I am trying to figure out how to create a flower petal by projecting the outline of the petal in one plane onto a spline line in another plane. It is simple to do in Solidworks, and here is a video of exactly what I am trying to do. I just do not know how to do this in Inventor. Please help!
Attach your *.ipt file here.
Essentially the same process in Inventor as in SolidWorks.
Hi! The equivalent command in Inventor is called Intersection Curve in 3D Sketch. Create or edit a 3D Sketch -> Intersection Curve -> pick the two curves individually -> Ok.
Many thanks!
Very very Thank you, it works and was so easy to do. I was trying do it during hours
Another option which you may find useful in a different situation is to extrude the top curve as a surface and then project the sketches onto that.
