Inventor Forum
Problems with the frame generator miter
3 REPLIES 3
448 Views, 3 Replies
Mit dem Gestellgerenreator wurde ein Gestell mit Gehrungen erstellt.
Nach dem hinzufügen weiterer Bauteile und Abhängigkeiten ist sind die Gehrungen nicht mehr richtig und das Gestell zu seiner Referenzgeometrie verschoben.
Wie lässt sich das Beheben und was wurde falsch gemacht?
Translated with Google Translate:
"With the frame gerenreator a frame with miter was created.
After the addition of further components and dependencies, the mitredions are no longer correct and the frame is moved to its reference geometry.
How can the fixation and what has been done wrong?"
kelly.young has edited your subject line for clarity: Probleme mit Gehrungen des Gestellgenerators
3 REPLIES 3
kelly.young
Hallo @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
If I understand the issue correctly, you have the frame generator to creating your staircase but it does not resize.
When I go into the Frame sketch Referenzrahmen does not have any dimensions and cannot be edited.
Typically the frame generator process is driven by the sketch, where you have it set by dimensions and can change to update the model. However you created this from the beginning does not have these constraints or dimensions, it is a locked in sketch. Not sure how you did that.
I try to draw the sketch to include as many features and frame parts as I can so that if I need to re-use or change something it is all based off one sketch.
Here's a quick setup of the frame generator, maybe you could tell us what kind of workflow you are using and we can tell you where to improve?
Please select the Accept as Solution button if a post solves your issue or answers your question.
kelly.young
Hello @Anonymous were you able to inspect your assembly and find how your frame generator constraints and dimensions are setup?
in reply to: kelly.young
Thanks for th short video.
It helped a lot and i think I now the issue.
