Time goes by. I started another animation, but problems with camera settings and recordings are still present.
- AVI records are crashing
- Large WMF records are crashing the same
- Only image recording of 625 images was possible (25 seconds with 25 images per second). Combining was done with Windows MovieMaker
But: Even I could place some camera settings in Studio timeline-run, they were broken with video recording. I only succeeded in recording a fixed view. Result is attached.
This was no easy task.
- Lots of switching between Studio and Assembly environment were needed, for resetting startup conditions in Studio
- Time and start-end position changes in Studio are tricky
Well, I could solve these issues by lots of trials and errors. But now I'm stuck again with camera settings. Only garbage comes out.
That's hidden in the fixed view record:
- Left door of cabin closes
- 4 outrigger feet move up, together with gear movement
- 4 outrigger feet move inward, together with gear movement
- Crane moves along path, returns and comes back
- While this movement, motor pistons, crank, and differential gearing are moving, too
- Wheels are rotating and changing their steering angles in the turn
This could be much better, with more options in camera setting. I suspect, that this is poor.
But perhaps it's only my lack of skill. I can provide a file set, if anyone likes to improve that result.
Walter
Walter Holzwarth
