Problems with constraints after update
nevillesyson9204
nevillesyson9204
After the last Inventor 2019 update , the mate constraint now defaults to flush . This is very annoying as it has always defaulted to mate . When in flush mode , it does not allow you to select an axis of a part so you have to do an extra click to change to mate . Is there a way to change the default to mate instead of flush ?
In version 2020.3.2. it will be a new feature, an improvement by then...
nevillesyson9204
Thank You for your help , any idea when that update will be available ?
 Still not sure why the default was changed in the first place though ?
johnsonshiue
Hi! I think @Anonymous was somewhat joking. 2020 is not yet released and it is still on Beta under NDA. I am not allowed to talk about it publicly. All I can say is that we are working on a solution which will revert the default constraint behavior (Mate) as opposed to partially last used. The solution should also be available on the coming update, 2019.4.
Many thanks!
Software Test Engineer
