Problems with Avantech Drawer components - iBoxes.
janarT35FJ
janarT35FJ
Hi!
I have made a lot of components of new Avantech drawers in different side heights and lengths - H77, H101, H139, H187, H251. I have little problem using drawers bigger than H101. Drawers in side height H77 and H101 works perfectly. Other doesn´t work as i would like to - just draw gabarite box into cabinet inside room and add drawer which i need.
If i use bigger drawer than H101, it crashes in main assembly. Sides just explodes somewhere and iMate doesn´t work correctly. It takes main assembly gabarite dimensions not block where i would like to add it. I made pack n´go file into dropbox and maybe you can check it out whats wrong - https://www.dropbox.com/s/vnihctoswsx7lwj/packngo.zip?dl=0
Thanks for your attention! 🙂
Janar.
A.Acheson
Hi Janar,
What version of inventor are you using? If possible can you attach a small assembly using pack and go including part files in a zipped folder as attachment to this post? or indeed attach images or video of the errors. Most users will refrain from following third party links to drop boxes etc and prefer a direct attachment.  It can be hard from the information in the post to determine where and what the issues are.
Regards
Alan
janarT35FJ
Hi! I am using Inventor Professional 2022.
Dropbox link where is small assembly with drawers - https://www.dropbox.com/s/vnihctoswsx7lwj/packngo.zip?dl=0
Janar.
