So i have problem with sweep command, I'm trying to create a cable from this red circle to the main circle on the building , it is showing a red outline, i tried many things and it still doesn't work.
[ The subject line and body of this post has been edited by CGBenner 4/1/24 ]
how can i fix this, and i have to do it with multiple cables, please help, im sending a file, so if someone knows how to fix it
Solved by CCarreiras. Go to Solution.
Hi!
you're trying to create the Sweet by an assembly feature. (green square)
Assembly features have "special rules" and don't behave totally as a normal tool applied in a part.
I suggest you create new parts for the cables instead of assembly features.
Hi!
BTW... i would use Frame Generator to create the cables in a few minutes.
First create a skeleton sketch, then apply tubes to that skeleton.
Check the file.
You need to create the remain cables using the same method for a quarter bridge, than use mirrors to complete the bridge.
Check the file.
Well. if you are novice, just don't use assembly features. in time you will understand why they exist.
You have now all the paths you need in sketch1 (green Lines), and you will use each line to do each sweep.
You have to create a profile for each sweep (yes... it sucks). Create each sweep profile as the video attached "createSweepProfile".
Then you will have a profile and a path, you just have to use sweep tool and select both: the profile and respective path.
After you have one quarter bridge ready, you can create 2 middle planes and mirror two times to have all the bridge:
Thank you so much 👍its done.
