Hey
I have a serious issue with Inventor style library. When im clicking on Manage styles i see only two tabs: Lightning and Text.
What should i do ? I tried reinstalling but it didn't worked . Switching active projects does not work either
Solved by 3D4Play. Go to Solution.
This is what you will see when you open the styles editor from a model (part or assembly) context. To manage other styles, like lineweights, layers, text formats, views, etc, you must open the styles manager from the .idw context.
