Problem with slide
Problem with slide
Message 1 of 13
Problem with slide
Hello!
I have been trying for a while now to get a sliding fuction to work.
ITs the grey here I try to slide, and then make them stop at the ends.
Now when i try to move the blue circle this happens:
The onlye thing i have done to this now is that the grey are constrained to the blue circle.
So any solution on how i can fix this?
Replies (12)
Message 2 of 13
mwighton
are you just using constraints or are you going to use this in an fea analysis?
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
Message 3 of 13
JDMather
Can you attach your assembly here?
Message 4 of 13
Here are all the files 🙂
Message 5 of 13
mwighton
Since you are using 2016 I can not view the file unfortunately. If you are using just assembly constrains you can apply a range restriction on the constraint. In the constraint window next to 'Apply' there is '<<' button. Click this and the limits can be added there.
God Bless
Mwighton
Message 6 of 13
JDMather
What software program are you using to get *.rar?  Is this a free program?
You are more likely to get response if you use Windows to compress the files.
Message 7 of 13
Hello
you can use rarlabs to open .rar files.
But i have attached .zip file here now.
Message 8 of 13
WHolzwarth
Machine.ipt and Slide.ipt are missing.
Several other files (not needed) are attached.
Walter Holzwarth
Message 9 of 13
oh sorry..
Here they are 🙂
Message 10 of 13
WHolzwarth
Here's a new file set (2016 data).
You can move 3 sliders by grabbing the red part.
Walter
Walter Holzwarth
Message 11 of 13
JDMather
Don't forget to add some real-world clearances between parts - can't manufacture perfect parts, and even if we could they would not slide due to friction.
Message 12 of 13
Wow, thanks for the help 🙂
Message 13 of 13
Thanks for the headsup JDMather, know all about clearances, and it can be some pain..
