Problem with rip command
SCASTILLO-RMI
Message 1 of 8
SCASTILLO-RMI
Attached is a simple reducer cone made from 14 ga stainless. I am trying to rip it to create a flat pattern, but despite following the step by step on several youtube videos I can't seem to get it to work.
Please take a look and let me know what I am doing wrong.
Thank you
Replies (7)
Message 2 of 8
n_Sovljanski
In attachment is file created in I2022.2. I removed shell feature and used Thicken on surface feature. Thicken feature adds material normally on surface what is necessary for sheet metal.
Message 3 of 8
Gabriel_Watson
3D Model (tab) > Convert to Sheet Metal > Rip
You will also need a line or point to point on the surface of the cone where you wish to create the Rip:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-B30BDD38-9CF6-496E-9133-52A59CDCAEE6
Message 4 of 8
SCASTILLO-RMI
Thanks for taking a look. Unfortunately I can't open the file as I am running 2021.
That said, I have used the rip command successfully on other parts that featured the shell command.
What is different about this part that shell needs to be removed?
Message 5 of 8
SCASTILLO-RMI
Yes, I have done that by following the example shown here:
https://www.google.com/search?q=rip+command+cone+in+inventor&client=firefox-b-1-d&channel=tus5&ei=gU...
I get as far as choosing the two points and then get an error message.
Message 6 of 8
n_Sovljanski
This cross section for shell
This is from Thicken
This is your modified sketch
Pay attention revolve will create surface
Cteate WorkPoint for rip
Apply rip on one point
Message 7 of 8
n_Sovljanski
Hi, I forgot two important things.
1 For thicken command input desired thickness
2. Convert your model part in sheet metal part
Message 8 of 8
SCASTILLO-RMI
Thanks for the pics, they pointed to the problem. I squared off both edges perpendicular to the rip line - as you show in your second pic - and the command worked.
