Inventor Forum
problem with lofting rails-inv 2011
3 REPLIES 3
Myles1
250 Views, 3 Replies
I have a fairly basic shim that I need to make, and I have my two sections set up (magenta in attached file), and 4 rails.  There seems to be a problem with one rail (orange in attached)  I have redrawn this sketch many times, many different ways, and is just won't work.  I can pick all other rails, but not that one.  I need all four rails to properly define this part.
Any ideas?
3 REPLIES 3
JDMather
in reply to: Myles1
Sketch1 is not constrained and I would never use magenta (or pink) as that is how Inventor highlights "sick" geometry.
Sketch2 is not constrained and I would never use magenta (or pink) as that is how Inventor highlights "sick" geometry.
Sketch4 is not constrained and shows a really "strange" dimension when the arc is dimensioned.
Sketch5 shows a really "strange" unmanufacturable dimension when the arc is dimensioned.
Sketch6 missing Tangent constraint and arc dimension doesn't match Sketch4.
Sketch11  missing Tangent constraint and arc dimension doesn't match Sketch5.
Sketch11 is not connected to Sketch1.
You might want to reaed this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
Myles1
in reply to: Myles1
Thanks, I'll take a look at the sketches.  There is a slight taper to this part that you may have missed.  That is why loft is being used.  (BTW the colors were only changed just for the purpose of making it easy to explain.)  It isn't something we generally do!
JDMather
in reply to: Myles1
Yes, I missed that originally and went back and edited my response.
I also noticed that if you use geometry constraints the only the line or the arc need be dimensioned - so pick the one that is the controlling factor (for manufacture and assembly).
I modeled it up from scratch - but I'm using a later release.
I am curious to see your true (dimensioned) design intent.
Also, are you aware that one of those faces won't be planar?
