Problem with loft
Problem with loft
roger
Problem with loft
roger
Inventor 2014 LT would not create the loft between the outer perimeters of sketch 8 and sketch 9. The preview looked perfect but it would not create the feature. Any idea why not? Thanks, Roger
I_Forge_KC
Hey Roger,
Lofts with a hollow section always cause headaches.
The solution is to do this as two lofts:
1) Loft the entire outer profile together as a join (when doing this, use the tree to select the sketch entities instead of the model)
2) Loft the inner profile as a cut
Your geometry is such that tangent/smooth on the cut will likely yield a problem. You might want to consider doing this as a shell instead of two lofts.
K. Cornett
Generative Design Consultant / Trainer
rdyson
In 2016, I was able to create the lofts as new bodies and then combine cut the two new ones and combine the results to the old body.
PDSU 2016
WHolzwarth
Here's my attempt (2014 IPT).
Walter
Walter Holzwarth
roger
That is exactly what I was hoping to get! Thanks! What was the trick?
WHolzwarth
Hi Roger,
trick was making the sections more similar to one another by splitting them at the symmetry plane.
As K. Cornett mentioned above, Inventor often has problems with lofting of internal regions together with outside regions.  By Splitting internal regions became open, and more friendly against lofting. Transistions can be adjusted, and after that mirrored again.
Walter Holzwarth
roger
I see - the split, loft, and mirror combination. Thanks again, Roger
