Problem with inventor installation
Claudiocorp
Claudiocorp
After downloading the file "Inventor_Professional_2025_Spanish_Win_64bit_db_001_002.exe", when you execute it, the following message appears that does not allow you to continue with the installation. "Cannot run the Autodesk Inventor Professional 2025 installer. If "Inventor_Professional_2025_Spanish_Win_64bit_db_001_002.7z is still downloading in your browser, wait for the download to finish and try running this file again. Please if you could help me as the days go by and the 30 day trial is getting shorter.
SBix26
You need two files-- the clue is in the filename of the one you have, which is file 1 of 2 (001_002).  The second file has the same name except it will be 002_002.
You should be able to find that in the same place you found the first one.  If you can't find it, or need more help, try the Installation & Licensing Forum.
Sam B
Inventor Pro 2025 | Windows 11 Home 23H2
Claudiocorp
Thanks!!
