- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey guys, I've had an issue like this before but there are a bit more variables in this particular part. Basically what I'm trying to do is this: I've got the face of my panel, then there is a flange that comes off at a 78.11 degree angle. One side of that flange is cut at a 44.33 degree angle, and from that cut, there is another flange. On the face of the panel on the same side as the cut on the other flange, I've got a 135 degree flange. What I need to do is put a corner seam between the two flanges with the flush faces. Whenever I click on one edge it selects, but it will not let me select the second. I've had this issue before when not having the faces perfectly flushed up, but I am just unsure of how to flush these up perfectly. As far as I can tell they are flush. Any help would be greatly appreciated. I've included the part for anyone to take a look at. The flanges I'm trying to seam up are named as such in the model tree.
Thanks guys.
