Problem with AcWebBrowser.exe
Since I have upgraded to Inventor 2018, I got resource issues due to acWebBrowser which consumed too much resources.
Here is what I do to reproduce the problem :
I have built an small program based on C++ and Inventor API, this small program enables to load files (STEP) and performed an analysis of the file topology (does it contains surfacis, is it an iPart,...).
When I run the program on several files, the computer starts to be very slow after some times and when I look at the machine resources, I see that ACWebBroswer is consuming far too much resources. (see attached files).
With previous inventor versions : 2017, 2016 ... 11. I didn't have this problem.
Is it a bug from ACWebBrowser?
Could you help me to solve it?
