Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello everyone,
Please guide me how we can add circular flange on the sheet metal part as shown below
One solution which I know is draw the profile and revolve it in 3D model but I do not think it is a correct way to add the flange (add two parts)
also we can not add corners and other stuff with one command like we can do in flange or contour flange command. With flange command we can not select circular edges but can select straight edges.
Thank you in advance and best regards,
Dnyaneshwar Maid
Hi Dnyaneshwar,
How abut Loft flange? I believe Loft Flange can help you in this case.
Hi, Xun,
Thank you for u r time and answer but with loft flange can we add flange on chord segment. for more information please see below picture
I want to add flange on yellow marked edge. If it is possible with loft flange can you guide please
Best regards,
Dnyaneshwar Maid
Hi Thomas,
I can not send you the part file..sorry but for more details please see below 2 pictures
I think with picture you will understand what are my requirements. Its a simple plain disc with some vent hole as marked in yellow where I want to add flange. With flange command I can not select edge as I mentioned in earlier post
Thanks a lot
BR
Dnyaneshwar Maid
Hi Dnyaneshwar,
Make a punch tool and add a punch on it, that's what you want.
Will create an example for you then.
Hi Dnyaneshwar,
Here are several similar case for your information.
https://forums.autodesk.com/t5/inventor-forum/placing-flanges-on-a-curved-part/td-p/3798896
Hope it helps!
We have the same issue I do it 2 different ways
1. offset the distance needed and extrude.
2. I draw a profile with the fillet and sweep it.
I hope this helps.
Thank you for reply but sorry I do not understand what you want to say with picture.
can you describe little bit. Also what I see in your picture is same problem for me.
Best regards,
Dnyaneshwar Maid
