Problem while doing a mold
Hi guys, i'm trying to do a simple bottle mold. I've already created the 2 solids i need (the bottle and the cube) but when i try to do the combine/cut step, the bottle solid stills remain. There's a cut but only on the edges.
Do you know what i' m doing wrong?
blair
Without seeing the file it would be tough to comment but it looks like you could do a revolve sweep using half of the sketch for each mold side. If you started your model centered about the Origin you will already have the Work-Axis in place to revolve.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
JDMather
Delete Face with Lump option.
Thanks you so much for your fast response sir!!! It worked just perfectly, new tool learned!
On the other hand, do you have any idea why did that happen? (Just the edges were cutted)
JDMather
The interior of your bottle was empty space.  Cannot cut anything with empty space.
Thanks you so much!
