Problem to Loft Blade profiles
i wanted to loft these Profiles for a blade design. But it didn't work till now.
I tried it with guide rails and with a center line. But no results.
Can anyone help me please ?
Thank you 🙂
CCarreiras
HI!
Don't use so many points to create the profile splines. Too many points are useless.
Use Spline by interpolation mode, not by control vertex
The lateral guides must be connected  the profile entities
CCarreiras
Hey!
Thanks for your hints.
When I use the interpolation mode the profile looks very curvey.
Why should I use the interpolation mode ?
CCarreiras
Hi!
Observe the results... Interpolation will garantee that the spline really conetct to the points you have.
Curvey... use less points. You dont need to use all the points, after all, the points are from a tangent curve between them, so, the sopline will maintain that.
CCarreiras
Deleted a few Points and it looked better than made new guide lines and the loft worked perfectly.
Thank you Carlos  🙂
