Inventor Forum
Problem Profile
9 REPLIES 9
Message 1 of 10
265 Views, 9 Replies
Problem Profile
See CF. I cannot extrude profile in attached ipt. Why? I am quite sure loop
is closed, lines are all normal etc.
Willy Driessen
9 REPLIES 9
Message 2 of 10
Hi!
Have You tried "Close Loop"-command?Could you post that ipt to CF. It would
be much easier to examine! As far as I understand there should be no
problems!
Alpo
Message 3 of 10
Oh it was already there, sorry!
Alpo
Message 4 of 10
Willy,
See my reply in CF
Cheers
Rob Singlehurst
"Willy Driessen" wrote in message
news:D5E9D85B9B7D3186CA322D4167C9384D@in.WebX.maYIadrTaRb...
loop
> Willy Driessen
Message 5 of 10
Rob,
making two lines colinear should be done by the coincident constraint as
well, isn't it? I see that just deleting this coincident contraint (first
line endpoint to the second line) makes the profile extrudable again. Stange
isn't it?
Willy
Message 6 of 10
Weird,
One of the many IV "features" that keep cropping up!!!
Cheers
Rob Singlehurst
news:ACA9FEA25F88DBE08EEDF2C3C0AD195F@in.WebX.maYIadrTaRb...
> Rob,
Stange
> isn't it?
> Willy
Message 7 of 10
This is strange indeed.
As other have said, there seems to be a problem with one of the sketch
constraints. See jpeg in CF attached
If you show the constraints you will see that Inventor thinks the line is
coincident with a line that it is not attached to.
If you delete the constraint, move the endpoint of the line and then place a
new coincident constraint it seems to then work.
Any clues on how you managed to get it into this state???
Best Regards
Richard Rankin
Autodesk Manufacturing Solutions (Support)
Message 8 of 10
Willy,
BTW I have logged this as CR ID 519770 for further investigation
So any clues as to how you got it into this state would be appreciated
Best Regards
Richard Rankin
Message 9 of 10
Richard,
I started this sketch on XY plane. At that time there were some master
sketches derived. I projected just a line and a circle out of the master
sketch. Then sketched the profile you've seen, placed some dimensions and
constraints and fixed the profile by a tangent and coincident constraint
towards the master sketch projected circle and line. That was all I did.
Willy
Message 10 of 10
It doesn't sound as if you have done anything mysterious.
OK. Well, I hope we have enough to find the root cause already
Thanks for bring this to our attention
Best Regards
Richard Rankin
