Inventor Forum
Problem Inventor 2020 with customized buttons for VBA Macros
9 REPLIES 9
Message 1 of 10
AW-WIFO
1498 Views, 9 Replies
I have some problems with customized buttons for VBA Macros in Inventor 2020.
Every time I have closed Inventor and restart it they have disappeared from the Tools-tab and the Quick access toolbar.
I have to manually add them every (re)start of Inventor, by going to: Tools -> Customize -> Ribbon -> Un-check and Re-check one of the check-boxes in the right column.
Why they won't show up automatically?
With previous versions of Inventor (2019, 2018, etc.) we didn't have any problems with this
and the code behind it didn't change at all.
9 REPLIES 9
Message 2 of 10
Vitalla
in reply to: AW-WIFO
I'm having the same issue as we are just migrating from 2018, have you found any solution to this?
Message 3 of 10
mcgyvr
in reply to: Vitalla
@Vitalla  Are you able to make other "non-macro" related changes to the ribbon UI? Can you just add any normal button to the quick access toolbar and have it not disappear?
This could be permissions related.
Message 4 of 10
Vitalla
in reply to: mcgyvr
@mcgyvrYes,  other items such as iProperties seem to stay when I reopen inventor. I will look into permissions.
Message 5 of 10
Vitalla
We had Inventor Version 2020.1 installed. Once we applied the updates to version 2020.2.1  this problem went away and all the macros showed up & stayed.
Message 6 of 10
BG_Ammel
We're have the same issue and updating the versions did not help; now at 2020.1.1.  Still have the same issue.
Message 7 of 10
BG_Ammel
Issue is solved by creating custom Icons for the Macros.
Describe in this posting:
https://forums.autodesk.com/t5/inventor-customization/no-customicon-to-vba-macro-button/td-p/9061649
Works every time now with the custom Icons.  Macros without custom Icons will not reload when the application restarts.
Message 8 of 10
Bert_Bimmel
in reply to: BG_Ammel
This is not a solution, it's a workaround.
Doesn't work for me: My macro-buttons won't show up at all, respectively, they show up, and one instant later, they're gone again. On my colleague's workstation Inventor crashes when trying to show them.
So what now?
Message 9 of 10
Vitalla
in reply to: Bert_Bimmel
@Bert_Bimmel
Are you on version 2020.2.2 ?
Per https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=Inventor_ReleaseNotes_Updates_2020_2_fixed_bug...
The last item on version two release:
"Resolved issue where text on customized ribbon commands was missing and the order was reversed. INVGEN-26616"
I believe this is what was causing the issues, so when I went from 2020.1.1 to 2020.2.1 we applied the fixes from 2020.2.
Message 10 of 10
Bert_Bimmel
@Vitalla
Nope, My version was 2020.2. Now its 2020.2.2
Works now, although it apparently had nothing to do with the mentioned bugfix (i.e. the description did not really match my symptoms, plus this bugfix had already been installed)
