Hi @karl.trolenbergV2BMK
If you believe the translation went through without any errors according to the translation report (htm file in your browser) then you can try checking the following:
1. transforms or bounding boxes of those missing parts are incorrect or wrong
- maybe those missing parts have empty bounds or bad transforms resulting in non-display
- this would be indicative of a bad translation (either export or import)
- you can try exporting as STEP from swx and re-importing into inventor and see if you have issues
2. Bad bodies in your file
- After opening the assembly in Inventor - hit F7
- Inventor should do a sanity check of all bodies and provide a report
- if there are errors, it will be displayed, please copy/paste that and post here
- you would have to heal the errors to get the bodies to be displayed again
3. Display Parts are obscuring your hidden parts
- this is an unlikely case, but in the event the parts displayed on screen are too big and the hidden parts are too
small and maybe they are being obscured?
4. After opening the file in Inventor, can you export the Inventor Assy to a STEP file and attach that to avoid confidentiality issues?
-shiva
Shiva Sundaram
Inventor Development
