Problem converting inventor idw file to dwg
cjfgns1003
cjfgns1003
When converting idw to dwg, what is the way to set the Linetype scale below to 1 for the same?
johnsonshiue
Hi! Likely it is a bug or a corrupted style causing translation confusion. Another workflow to consider is to save the idw as Inventor dwg. Open the dwg file in AutoCAD and use EXPORTLAYOUT to export the sheets. Usually you will get more consistent result.
Many thanks!
Software Test Engineer
