Problem activating product
Message 1 of 17
I am a PhD student who wanted to use Inventor. After installing and receiving the serial number by e-mail, I wanted to activate the product, but I still get the error: "The entered serial number is incorrect"
How is this possible if I am entitled to 3 years of activation?
Product:Inventor Professional 2020
License Type:Education Stand-alone
Access Type:Single-user
Authorized Usage:Install on up to 2 personal devices*
Product Key:797L1
Serial Number:xxx-xxxxxxxx
Term:3-year term
Replies (16)
Message 2 of 17
Mark.Lancaster
@Anonymous
For Installation, licensing and activation please use the installation and licensing forum https://forums.autodesk.com/t5/installation-licensing/bd-p/24 and not the product based forum.   I will have the moderator relocate your posting there to best suit your needs.
Although the forum rules caught you serial # and "X" it out, for the future please do not share your serial # or sensitive info on a world wide public user forum.
Just to check, when you installed Inventor 2020, did you pick Inventor or Inventor Professional?   And I assume you download the 2020 version and not another version?   When you launch Inventor does its state Inventor Professional?
Mark Lancaster
Message 3 of 17
I downloaded the Proffesional 2020 version from: https://www.autodesk.com/education/free-software/inventor-professional and I have a trial version
Message 4 of 17
Mark.Lancaster
@Anonymous
But when you installed, there's an option to install Inventor standard or Inventor professional.   The installer is for both levels of Inventor   When you launch Inventor what does it state in the WIndow Title?
Mark Lancaster
Message 5 of 17
Both versions appear. I chose Professional 2020. And which version is for me?
Message 6 of 17
mcgyvr
The full blown Inventor Professional version is given to students..
Activate and enjoy..
Message 7 of 17
This is the version I installed, but when activating I get an error that the code I received in the email is incorrect. How is this possible?
Message 8 of 17
mcgyvr
Please post a picture of the "About Inventor" dialog box (hit the dropdown arrow next to the question mark icon in the upper right hand side of the screen) to prove you have Inventor 2020 Professional Installed.
Just like this..
Message 9 of 17
I have a trial version for 30 days, now select only 5 of them for me. Only this version can be downloaded from this link, which is under me in the first message.3 rys.jpg4 rys.jpg3 rys.jpg
Message 10 of 17
Mark.Lancaster
@Anonymous
Can you go to manage.autodesk.com and product/services.
Show screen shot of your Autodesk Inventor 2020 listing and blur out your serial # in the image before posting.
Mark Lancaster
Message 11 of 17
Message 12 of 17
Message 13 of 17
Mark.Lancaster
@Anonymous
Can you translate to English what it states under your Inventor section of manage.autodesk.com
Mark Lancaster
Message 14 of 17
Trial version, only six days to the end trial version.
Message 15 of 17
Mark.Lancaster
@Anonymous
Your under the trial section.   (purple arrow)
What is under the all product and services (red arrow)
In the end it sounds like you have sync issue with your Autodesk Account.   Since its related to educational you will need to contact their support team https://www.autodesk.com/education/support/edu-contact-us-form
Mark Lancaster
Message 16 of 17
I've been trying to solve this problem for several weeks. Where you directed me I was and they did not help me. I'm slowly losing faith that I can install it
Message 17 of 17
leowarren34
@Anonymous
Going through your posts there appears to be a 'disconnect' between your serial number and account.
As you have requested a serial number, a serial number has been generated but not appear in your management window. So as Mark suggested EDU support will be able to link them together and get you working
@Mark.Lancaster Is this becoming common? As I've seen quite a few similar Inventor issues in a short time.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
