Inventor Forum
Problem About Defining User Parameter Type As Square Meter
4 REPLIES 4
480 Views, 4 Replies
I have a problem about defining user parameter type as square meter. I know i can change it from unit settings but i need to add this as a rule.
After "UnitsTypeEnum." there is no selection for square meter.
oUserParams.AddByValue("MyParameter","MyValue", UnitsTypeEnum.)
Other question is what i need to do to work this rule both part and assembly ? Changing "PartDocument" with "Document" is not working.
Here is the simple code.
			Dim oParams As Parameters
			Dim oPartDoc As PartDocument = ThisDoc.Document
			Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
			oParams = oPartCompDef.Parameters
			Dim oUserParams As UserParameters = oParams.UserParameters
			Try
			  p = Parameter("MyParameter")
			Catch
			End Try
4 REPLIES 4
Sergio.D.Suárez
Hi, try to execute the following rule in part or assembly file.
you must remove the string "Part" in the document definition, and in the component definition.
In the end I have placed some common units for your created parameter.
Dim ParamValue As Double = 6
Dim ParamName = "MyParameter"
Dim oDoc As Document = ThisDoc.Document
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oParams As Parameters = oCD.Parameters
Try
	oParams(ParamName).Expression = ParamValue
Catch
	oUserParams.AddByExpression(ParamName, ParamValue, 11270)
	'oUserParams.AddByValue(ParamName,6,11270)
End Try
Parameter.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
'kCentimeterLengthUnits 11268 Centimeter Length.
'kMeterLengthUnits 11270 Meter Length.
'kMillimeterLengthUnits 11269 Millimeter Length.
 I hope this helps with your problem. Cheers!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
in reply to: Sergio.D.Suárez
Hi Sergio,
Thank you for your help. It helps me to run the rule for both part and assy documents. However m^2 problem is continue. After i find a solution for that, i will accept your solution as well.
Well, solution was easy. Just add "m^2".
oUserParams.AddByExpression(ParamName, ParamValue, "m^2")
Sergio.D.Suárez
Excuse me I had not noticed the unit. Try the following rule. Cheers
Dim oUnits As String = "m^2"
Try
	oParams(ParamName).Units = oUnits
Catch
End Try
Mechanical Designer
