Printing out Paper Patterns from Inventor?
Message 1 of 27
Greetings fellow Inventor Forum Members, Using Inventor 2015 I have modeled a bowl with a 12 inch diameter and it has a height of 6 inches. In other words, it looks like half of a sphere. My goal is to slice the bowl into 5 equal slices along the center vertical axis of the bowl. Then my goal is to flatten all five slices and print each slice on a piece of 11 x 17 inch paper. The purpose for all this is to have patterns I can use to cut thin sheet metal in the shapes of the slices I flattened within Inventor. With the 5 thin sheet metal pieces cut to the shape of the pattern I will then be able to curve the thin sheet metal and weld all of the 5 slices together and end up with the same bowl in thin sheet metal that I modeled in inventor. The problem I am having within Inventor is figuring out what command to use to flatten each of the 5 curved slices onto a plane. How do I get Inventor to convert a curved slice of the bowl and layout flat on a plane so that I can print it out onto a piece of 11x17 inch paper? Any tips on how I can make this happen will be greatly appreciated. Thanks in advance for the help.
Replies (26)
Message 21 of 27
JDMather
Do you want a "sphere" or do you want what you had in your assembly?
(Refer to the image that I posted in message #17.  Did you not see that it does not go to the poles (this is your part file?))
Message 22 of 27
Okay, I understand how to fix it! I didn't see that in my original part file. Thank you for pointing this out!
Message 23 of 27
JDMather
See the attached assembly.
Message 24 of 27
Thank you so much this helped a lot! Have a nice day!
Message 25 of 27
The intent is to create a 1/4 sphere with an inside diameter of 42 inches (pole to pole measure)
Message 26 of 27
JDMather,
Thank you for the assistance.
We hadn't thought about using a triangle to create the petal, very ingenious.  The goal for Chetna (she is our Co-Op) is to create 1/4 of a sphere with a 42" diameter (pole-pole) measure.
It will be utilized in a material deflection plate to ensure a better containment than original design.
Message 27 of 27
JDMather
@Anonymous wrote:
....inside diameter of 42 inches
I set kFactor = 0 for no bend deduction on inside radius for the template.
No calculations are needed.
Simply edit radius (and angle if more gores desired).
Inventor will take care of the rest.
