okay everybody
let me explain myself
1. Like you have all said, in Inventor you can't print a specific window which you pick yourself accurately
by selecting the 2 opposite corners, like you can in AutoCAD.
2. The way Inventor works with its idw , is indeed quite different from the way AutoCAD works
with its paperspace, viewports and modelspace, and indeed it is much more rare
to need that particular print window function in Inventor than in autocad
3. I do have a very specific use for it!
I work side by side in inventor (3d models and detailing for manufacture) and AutoCAD (2d layouts of large areas of formwork
& supportwork).
I have had occasions where I have not been able to print to A1 for various reasons (at home I only have A3 printing facilities
and at work the last 2 days our A0/A1 printer has been out of action leaving only our A3 printer)
In these instances,I have divided up the A1 border into 4 equal A3 sections, and printed each, using print window & selecting
corner to corner of each A3 quarter. I then cut the 4 inner sides with a scissors and sellotape the 4 A3 quarters together
to give me my A1 print.
Now this is easily done in AutoCAD, but can't be done in Inventor.
So the drawings I have done in Autocad I have been able to print as 4 A3's stuck together to give an A1.
The drawings I have done in Inventor I have not been able to do that, and have just had to print them as smaller A3
4. Thus in conclusion, this is not really a good enough reason to actually have that function in Inventor, but it would
have been nice for me if it was there, and I just wanted to find out if it was possible. Now I know that it is not.
Michael Kovacik
AutoCAD 2d & 3d(20yrs) & Inventor(7yrs) Manufacturing(30yrs) Draughtsman
Autodesk Product Design Suite Ultimate 2017
Johannesburg, South Africa
