Print idw with BOM order
aries.1482
aries.1482
I try to print all idw related to an assembly used task scheduler, it's ok. But i want to print with right order as they were sorted in assembly BOM and it is very tedious because i must chose idw file one by one. Any solutions for me!? Thanks!
Xun.Zhang
Hello @aries.1482,
It is possible, you can export part list to xls and then copy to a txt file, leverage API with VBA code to print from this list one by one.
Hope it helps!
Xun
aries.1482
Thanks for reply, i think it is possible Smiley Very Happy; but i'm not friendly with VBA, can you post code here?
Xun.Zhang
Here is a sample file to export drawing to PDF with a list file for your reference.
Hope it helps!
Sub Main()
    Dim arrFileslist() As String
    arrFileslist = GetFilesFromTxt
    Dim iStep As Integer
    For iStep = 0 To UBound(arrFileslist)
    On Error Resume Next
            Set oDoc = ThisApplication.Documents.Open(arrFileslist(iStep), True)
            Call Export2PDF
    On Error GoTo 0
    Next
End Sub
'Get all files from txt files
Public Function GetFilesFromTxt() As String()
    Dim strLine As String
    Dim strFilesListArr() As String
    Dim k As Integer: k = 0
    Open sFilelistTxt For Input As #1
    Do Until EOF(1)
        Line Input #1, strLine
        ReDim Preserve strFilesListArr(k) As String
        strFilesListArr(k) = strLine
        k = k + 1
    Loop
    Close #1
    GetFilesFromTxt = strFilesListArr
End Function
Public Function Export2PDF()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
'Dump PDF
Dim oPDFAddIn As TranslatorAddIn
Set oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim oPath As String
oPath = "C:\temp" ' PDF save folder
Dim oFileName As String
oFileName = oDoc.DisplayName
oDataMedium.FileName = oPath & "\" & oFileName & ".pdf"
Call oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
Dim oSheets As Sheets
Set oSheets = oDoc.Sheets
For Each oSheet In oSheets
    FileName = oPath & "\" & oFileName & "_" & Left(oSheet.Name, Len(oSheet.Name) - 2) & ".dwg"
Next
Call oDoc.SaveAs(oPath & "\" & oFileName & ".dwg", True)
End Function
Xun
rhasell
