Prevent objects in assembly to cast shadow / reflection
wellerchen
Message 1 of 16
wellerchen
Hi, is it possible to render an assembly in inventor / studio, and prevent some objects to cast shadows and reflection in the others?
The idea is to sketch a setup with mirrors, lenses and a laserbeam, where the beam (manually modeled) is visible, but does not cast a shadow, or the reflections are visible in the other objects of the assembly...
Maybe some other software is useful here?
Thanks in advance!
Replies (15)
Message 2 of 16
As I know this is not possible within inventor studio.
And in my opinion Inventor studio will only be used for quick rendering or animations.
A better option is to make use of a real render program.
Message 3 of 16
mdavis22569
Check out
https://knowledge.autodesk.com/support/inventor-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/I...
Mike Davis
Message 4 of 16
mdavis22569
Personally I think that looks pretty good for not being a real rendering program.   Nothing special was done here to have it look like this ...
I think a lot of people who post some great renderings from Inventor Studio would disagree with ...
Mike Davis
Message 5 of 16
wellerchen
in principle, the rendering capability of inventor studio is satisfactory for my needs, so that is not the issue.
the detail I want to resolve is the reflection of one individual object in all other ones. see the example picture attached, the 'beam' propagates through the lens (top left) and is then (manually) reflected from the mirror. the polished surface however also shows a reflection itself, as if the beam was a solid object. being not so physically correct to see the beam at all in the first place, it is much more disturbing to also see the mirror images.
maybe I did not find the part about that issue in your link?
thank you!
Message 6 of 16
mdavis22569
Can you share it ....
Mike Davis
Message 7 of 16
JDMather
Do you really need Studio Render
or
would Realistic Visual Style without shadows or reflections serve your needs?
Message 8 of 16
wellerchen
@JDMather: in principle yes, the thing is, the reflections button you highlighted is only for the ground plate, not within the objects.
@mdavis22569: see attached zip, hope it works that way!?
Message 9 of 16
mdavis22569
I'm still getting it on the polished surface.   Might need to change that face property ... but I'm trying different options
Mike Davis
Message 10 of 16
Daniel248
Here's another ideea:
Rendered as two separate images in Studio, and post-processed in GIMP.
Spoiler
What’s interesting, a mirror doesn’t show its own shadow… is that a good or a bad thing for a Vampire? ;-)) Smiley Happy
Message 11 of 16
wellerchen
That might be a suitable alternative. Although I still have hope for a 'not manual' solution Smiley Happy
Message 12 of 16
wellerchen
@mdavis22569: did you have any success trying different options? otherwise I will then take Daniel248's advice and accept the solution...
Message 13 of 16
mdavis22569
i haven't played with it again ...I'll do it some more this weekend if you want
Mike Davis
Message 14 of 16
wellerchen
yes, that would be great. thank you in advance! 🙂
Message 15 of 16
mdavis22569
something like this
png
Mike Davis
Message 16 of 16
May I ask how to realize the red and blue light path?
What's the setting for materials?
Qiang
