Message 1 of 17
As per the title, how do I publish an image without the background?
also if you want it white ...set it to presentation
Sorry, but I think I'm missing something here.
How do you bring up the Render Image dialog box?
Where do you want to get the presentation from ...
provide a bit more info ...also what version of Inventor?
Go to Environments tab then Studio. Click Render Image and follow my steps. This will give you a transparent background.
This is me assuming the version of Inventor you're using.
I feel like we've crossed wires here.
I am using the Presentation environment within Inventor 2017.
This is all I have:
so you've made a new IPN with an Inventor 2017 template .
For images I typically go straight from the ipt and into studio to render images with a transparent background (the workflow I've suggested above). I rarely use the presentation environment to do this. Hopefully another member can provide some insight.
can you give a screen shot ..
I want to see what background you're talking about
Thanks, Jacob.
Ah you're trying to actually get the background of the model space removed. I understand now. The only solution I can think of is the one mdavis provided. A good article on this is one by Curtis http://inventortrenches.blogspot.com/2012/09/inventor-background-color-as-white.html
Ok, thanks. I appreciate the help.
It is a huge oversight by Autodesk to remove the feature though. No transparent background means I'll have to process all shots through Photoshop now.
Plus every time I want to run an animation, I'll have to change backgrounds.
Thanks to everyone else.
Apparently no one here has 2017 R2 installed. Autodesk added it after i pointed out in the beta site that it was a crucial part of the sotware that was missing and something a lot of users desire now that Publisher is gone.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
