Presentation: How to publish an image without the background
bowen192
Message 1 of 17
bowen192
As per the title, how do I publish an image without the background?
Replies (16)
Message 2 of 17
Export image as png, check alpha channel.
Message 3 of 17
mdavis22569
also if you want it white ...set it to presentation
Mike Davis
Message 4 of 17
bowen192
Sorry, but I think I'm missing something here.
How do you bring up the Render Image dialog box?
Message 5 of 17
mdavis22569
Where do you want to get the presentation from ...
provide a bit more info ...also what version of Inventor?
Mike Davis
Message 6 of 17
Go to Environments tab then Studio. Click Render Image and follow my steps. This will give you a transparent background.
This is me assuming the version of Inventor you're using.
Message 7 of 17
bowen192
I feel like we've crossed wires here.
I am using the Presentation environment within Inventor 2017.
Message 8 of 17
bowen192
This is all I have:
8GclRNr
Message 9 of 17
mdavis22569
so you've made a new IPN with an Inventor 2017 template .
Mike Davis
Message 10 of 17
bowen192
I've created a new IPN, yes.
Message 11 of 17
For images I typically go straight from the ipt and into studio to render images with a transparent background (the workflow I've suggested above). I rarely use the presentation environment to do this. Hopefully another member can provide some insight.
Message 12 of 17
mdavis22569
can you give a screen shot ..
 I want to see what background you're talking about
Mike Davis
Message 13 of 17
bowen192
Thanks, Jacob.
xS2lNOK
Message 14 of 17
Ah you're trying to actually get the background of the model space removed. I understand now. The only solution I can think of is the one mdavis provided. A good article on this is one by Curtis http://inventortrenches.blogspot.com/2012/09/inventor-background-color-as-white.html
Message 15 of 17
bowen192
Ok, thanks. I appreciate the help.
It is a huge oversight by Autodesk to remove the feature though. No transparent background means I'll have to process all shots through Photoshop now.
Plus every time I want to run an animation, I'll have to change backgrounds.
Thanks to everyone else.
Message 16 of 17
mflayler
Apparently no one here has 2017 R2 installed.  Autodesk added it after i pointed out in the beta site that it was a crucial part of the sotware that was missing and something a lot of users desire now that Publisher is gone.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 17 of 17
This is awesome! Yeah, I haven't had a chance to install R2 yet. So nice to see this implemented.
