Presentation File with Reference Assembly's
OK here's our issue. Upgraded to INV 2017.4.1 from way back. Not sure of all the features in 2017 Presentation files since our upgrade covered a lot of territory. Autodesk user since 1993, Inventor since R5 so I have some history.
Our issue is creating a presentation file and associated drawing file (IDW) that involves multiple top level assembly's.
As an example, say I have a model of a car. That is my top level. Under that would be major assembly's of the Engine, Transmission, Cooling System and so forth. Each of these secondary assembly's have their own BOM.
Now say that I want to do a presentation of the Cooling System only but I also need to show the Engine assembly in that drawing as a source of reference for locating some mounting points for items found in the Cooling System.
So, my question is, within the IPN environment, is there a way to load more than one assembly file and then only explode the assembly file I want to use in my IDW? I do not want to create an assembly of in my example of the Engine and Cooling System since this would only screw up my master assembly by having duplicates.
I would really like to know if in the IPN environment, more than one assembly can be loaded and then only one exploded for the final view in the IDW?
This is common in many Parts Books/Manuals where only the parts that are necessary to the Parts List are shown while supporting parts are still displayed in the background.
The only solution we have been able to come up with is to load the reference assembly files as separate views in the IDW. This is then problematic as if the view moves then all the alignment or sketch geometry is out of sync with these reference views.
Any help would be greatly appreciated.
John
