Posts
Posts
Message 1 of 25
Posts
I am using inventor to wright for a C & C mill it wrights correct but posts backwards ?
( It wrights C & C but posts Autobody ? ) I'm not sure if its a simple fix or if I have the wrong program ?
Replies (24)
Message 2 of 25
JDMather
Is this an Autodesk Inventor question or is it really really
and Inventor HSM question?  https://camforum.autodesk.com/
Can you elaborate on your question?
Message 3 of 25
yes
Message 4 of 25
JDMather
OK
Message 5 of 25
mcgyvr
cravin77,
Please attempt to repost your question so we can understand it..
Its very unclear what the problem is.
can you provide an image of the problem or your actual ipt file?
Message 6 of 25
I am using the inventor program to wright to my C & C & it works ok in the simulation but when i post it in inventor for my C & C it wrights it backwards     ( or ) in autobody
Message 7 of 25
mcgyvr
wright should be write
C & C should be CNC
Whats "autobody" ??
Which CNC machine do you have?
Which post processor are you using?
Are you sure your UCS (XYZ indicator) is pointing in the correct direction in the CAM setup?
Can you please post the ipt file here so we can look at it?
Message 8 of 25
yes it is X Y Z and everything looks good in simulation but when it post it wrights it X Y & Z are backwards to the mill and it comes out as an NC. file
Message 9 of 25
Mark.Lancaster
Inventor out of the box does not have CNC capabilities.   Are you using Inventor HSM or some other CNC application for Inventor?  It helps everyone if you gives us more information.
Mark Lancaster
Message 10 of 25
mcgyvr
Please be more specific and actually try to answer ALL the questions that are asked to you...
Can you please post your ipt file?
Can you please let us know which post processor you are using?
Can you please also post your nc file?
Thats 3 questions.. Please respond with ALL the information I am requesting
Message 11 of 25
 its an add on to inventor called CAM it translates to a C & C
Message 12 of 25
CNC = Computer Numerical Control
C & C = Gibberish (Or C&C Music Factory)
Message 13 of 25
Mark.Lancaster
"its an add on to inventor called CAM"...   <-- Who makes it?   If its not an Autodesk add-on product (like Autodesk Inventor HSM) then you need to contact the Vendor of the add-on.
Mark Lancaster
Message 14 of 25
CNC
Windows 7
intel core i7
Message 15 of 25
inventor makes it
Message 16 of 25
its an add on to invetor because not everyone needs the add on for CNC
Message 17 of 25
Are you talking about InventorCAM?  Which is NOT made by Autodesk?
Message 18 of 25
yes it in post 11 right next to tools
Message 19 of 25
mcgyvr
Cravin77,
Please use this link to request support.
http://www.inventorcam.com/us/support/support/
InventorCAM is NOT an Autodesk product.. As such it is beyond the scope of this forum.
I do not have InventorCAM so I cannot see your potential toolpaths so I cannot check the validity of the NC file.
Message 20 of 25
Its is Autodesk Inventor HSM
