Hey all
What is the quickest way to fillet the top of this post. Just can seem to work out how to do it.
Cheers
Solved by JDMather. Go to Solution.
Revolve-Cut, just like the real world operation.
Attach your *.ipt file here if you can't figure it out.
Two Techniques attached.
I attached example above - the forum is broken, you must zip to attach.
Hi! I don't believe the fillet can be done by using Inventor Fillet command. The round is more like a Revolve or Sweep cut. Inventor Fillet tries to smooth sharp edges, not carving faces.
Many thanks!
